Saturday, December 27th, 2008 AT 5:29 PM
While I was driving I made a left turn and heard a popping sound after that my car wouldnt go forward or back, goes in gear, good pressure in clutch but makes a grinding noise when I lift the clutch, put camry up in the air found that when started the axle turns on the passenger side as it should and the driverside sits still as it should, problem is the passenger side axle is turning from the tranny with the rest of the axle but the wheel wont turn making a grinding noise
