2007 Toyota Camry Oil Filter Location
JAKE151
Where is the oil filter located on a 2007 Toyota Camry with a 2.4L engine?
Nov 19, 2007 at 3:53 AM
  • 75,988 POSTS
The oil filter on the 2.4l is located on bottom of engine, near drain plug , towards front of car . It is in a slightly higher spot then the drain plug.
Nov 19, 2007 at 6:26 AM
Suggested Repair
Look for the oil filter on the bottom of the engine, near the drain plug and slightly higher, toward the front of the car.
Conversation Summary
The owner asked where the oil filter is on a 2007 Toyota Camry with a 2.4L engine. The expert said it is on the bottom of the engine near the drain plug, slightly higher and toward the front of the car.
