Where is the oil filter located on a 2007 Toyota Camry with a 2.4L engine?
Nov 19, 2007 at 3:53 AM
Look for the oil filter on the bottom of the engine, near the drain plug and slightly higher, toward the front of the car.
The owner asked where the oil filter is on a 2007 Toyota Camry with a 2.4L engine. The expert said it is on the bottom of the engine near the drain plug, slightly higher and toward the front of the car.
