More than likely a sensor is bad, TPS, coolant temp, MAP/MAF or a clogged convertor. Do you have a check engine light?
Usually when a sensor fails or is out of its defined range the ECM will default to a rich condition.
If the convertor is clogged it is more than likely caused by a sensor failure.
SPONSORED LINKS
Tuesday, December 26th, 2006 AT 10:34 AM
