Hi there,
There is only so much you can remove on a Camry door. To remove your dint, you will have to remove the door trim to access the inner panel, this is not removable and there is not much access to the outer panel either. Depending on where the dint is (in the middle I suspect) you may be able to remove the window regulator and give it a knock out, but what panel beater use is a up dated version of a slide hammer. If you are able to make one it should do the trick. You need a metal round bar and a heavyweight that will slide up the shaft. On the end there is a corse metal screw. Drill a small hole in the panel screw in the slide hammer and pull the dint out by sliding the weight up the shaft, striking the end plate you welded on so the weight wont fly off!
You may have to do this in a number of spots to pull the dint out enough, but watch your fingers it will bite you if you don't watch your self. Repaire hole if required.
Mark (mhpautos)
SPONSORED LINKS
Friday, November 30th, 2007 AT 6:36 AM
