HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Body
Door
SPONSORED LINKS
2000 Toyota Camry Door Squeaks
RODCHAR
MEMBER
2000 TOYOTA CAMRY
Noises problem
2000 Toyota Camry 4 cyl Two Wheel Drive Automatic
Hey all,
i heard that I shouldn't use wd-40 to stop door squeaks. Is this true? If so, what should I use?
thanks,
rodchar
Friday, June 6th, 2008 AT 10:16 PM
KHLOW2008
MECHANIC
Hi rodchar,
Depends on where the squeak is coming from.
If it is the door hinges or door restrictor, WD40 would dry up and won't last long.
Hinges would prefer some engine oil
Door restrictor you need grease.
If it is the door glasses, WD40 would damage the runchannels. Silicon or wax spray is recommended.
SPONSORED LINKS
Saturday, June 7th, 2008 AT 9:00 AM
RODCHAR
MEMBER
What is a door restrictor?
Sunday, June 8th, 2008 AT 11:42 AM
KHLOW2008
MECHANIC
Hi rodchar,
That is the piece of rod situated between door hinges. It prevents the door from opening too fast and over limit.
Monday, June 9th, 2008 AT 7:23 AM
RODCHAR
MEMBER
Thanks for the help,
rod.
Monday, June 9th, 2008 AT 7:35 AM
Please
login
or
register
to post a reply.
Related Door Content
Rust Beginning To Set In On A Scratch On The Door.
Someone Put A Six Inch Scratch On My Car Door And A Door Bang In The Middle. It Is A Single Scratch Most Likely Made With A Pointed Object....
Asked by
Godfrey Claudin Mathais
2005
TOYOTA CAMRY
How Do You Disassemble A 93 Camry Door?
I Have A 93 Camry. It Was In An Accident And Now Belongs To The Kids. There Is A Dent In The Front Right Passenger Door That Keeps The...
Asked by
Lori Wordell
1 ANSWER
1993
TOYOTA CAMRY
2001 Toyota Camry Broken Door Handles & Front...
Electrical Problem 2001 Toyota Camry 4 Cyl Automatic 112644 Miles I Have A 2001 Four Door Toyota Camry. Both Front Door Handles Have...
Asked by
mayday212
1 ANSWER
2001
TOYOTA CAMRY
2000 Toyota Camry Fix Side View Mirror
Some One Hit My Side View Mirror And Its Regulated From The Inside Automatic Now It Does Not Goup & Down
Asked by
James Ortiz
1 ANSWER
2000
TOYOTA CAMRY
2000 Toyota Camry Back Bumper Night Lights Dont Work?
Hi There - Thanks For Your Help - Love Your Website My Brake Lights And Turn Lights All Work In The Back -but The Back Lights That Turn...
Asked by
apoorvag
2000
TOYOTA CAMRY
VIEW MORE
SPONSORED LINKS
Door Not Closing
Door Lock Replacement
Fix a Door That Will Not Close
Online car repair manuals
