2000 Toyota Camry EGR Light Stays On
CRIPPLEGYRL
I have a toyota camry 2000 mileage120000, and my check engine light is on... so i got it checked.. they say it was the egr valve... so i took it home and cleaned it.... but my engine light does not turn off.. does that mean i have to replace the whole egr valve? or mayb i didnt clean it well? how do you clean the egr valve? and where should it be cleaned at? could it be that my sensor is haywire? also i what else can i do? im tryin not spend alot but just enough to pass smog... that is the reason i cannot pass smog... :|
Sep 4, 2007 at 6:39 AM
MERLIN2021
  • 17,250 POSTS
First, what was the code, by number? You may need a new one, but have the code read then have the light reset, if it comes on again, verify the code and post it here. You may need to clean the port under it.
Sep 4, 2007 at 6:52 AM
Suggested Repair
Have the diagnostic code read and the check engine light reset. If the light returns, verify the code. The EGR valve may need replacement, and the port under the valve may need cleaning.
Conversation Summary
The owner of a 2000 Toyota Camry with 120,000 miles has a check engine light attributed to the EGR valve. Cleaning the valve did not turn the light off, and the owner wants an inexpensive way to pass smog. The expert advises obtaining the code number, resetting the light, confirming whether the code returns, and possibly cleaning the port under the EGR valve; replacement may still be needed.
