1994 Toyota Camry EGR Light Returns
EMELYPITI
my car is a toyota camry 1994 155000 miles. the check engine light was on. the mechanic said it was the camshaft position sensor and the egr valve.he fixed it and the light is on again checked in the computer and said that it was the egr sensor. i am confused and i dont know what to do.
Sep 18, 2007 at 7:35 AM
FISHERMAN
  • 937 POSTS
[quote:081934c122="emelypiti"]my car is a toyota camry 1994 155000 miles. the check engine light was on. the mechanic said it was the camshaft position sensor and the egr valve.he fixed it and the light is on again checked in the computer and said that it was the egr sensor. i am confused and i dont know what to do.[/quote:081934c122]
Did he replaced the EGR or he just "clean it" ?
Sep 18, 2007 at 7:41 AM
BUZZSAW
  • 1,198 POSTS
[quote:95e9eb6344="fisherman"][quote:95e9eb6344="emelypiti"]my car is a toyota camry 1994 155000 miles. the check engine light was on. the mechanic said it was the camshaft position sensor and the egr valve.he fixed it and the light is on again checked in the computer and said that it was the egr sensor. i am confused and i dont know what to do.[/quote:95e9eb6344]
Did he replaced the EGR or he just "clean it" ?[/quote:95e9eb6344]
and it probally wasnt the egr valve itself, probally the switch-over valve to it, its where the vaccume comes from
Sep 21, 2007 at 4:23 PM
Suggested Repair
Confirm whether the EGR valve was replaced or only cleaned. The returning code is more likely from the vacuum switch-over valve that supplies vacuum to the EGR than from the EGR valve itself, so have that valve checked.
Conversation Summary
A 1994 Toyota Camry with 155,000 miles had a check engine light. A mechanic attributed it to the camshaft position sensor and EGR valve, but the light returned and a scan then pointed to the EGR sensor. Experts asked whether the EGR was replaced or only cleaned and suggested the vacuum switch-over valve is the more likely fault.
