2004 Toyota Camry ALT Fuse Removal Fix
JANEYDAVIS
I am trying to change the fuse in my 2004 camry. It is the Alt. fuse, one of the larger ones, I tried to pull it out and realized that the longer metals parts that go into the box are screwed in. How do I get the middle of the fuse box out. I already tried to unscrew the main screws and it still wont seperate from the bottom, so I am unable to unscre the metal legs of the old fuse.
Oct 13, 2007 at 10:17 AM
FISHERMAN
  • 937 POSTS
[quote:83b5e7cefc="janeydavis"]I am trying to change the fuse in my 2004 camry. It is the Alt. fuse, one of the larger ones, I tried to pull it out and realized that the longer metals parts that go into the box are screwed in. How do I get the middle of the fuse box out. I already tried to unscrew the main screws and it still wont seperate from the bottom, so I am unable to unscre the metal legs of the old fuse.[/quote:83b5e7cefc]
Hello !!
Well, this is kind of tricky..
See on the sides? there is a couple of "locking tabs" you should make them release the fuse mounting plastic..once released pull the wires (with care) until you can fit an a small socket with the ratch (1/4 square) the smalllest you got On the side screw..i don`t remember the size of the socket.. 10 mm ? not sure.. i
Well ...ts hard but you can do it!
that its a really bad design!
you are going to drop one screw (I drop both of them the last time i did it LOL)
let us know if you have any question !
Yes... we`ll be here !!
Good Luck!
Oct 13, 2007 at 4:06 PM
Suggested Repair
Release the side locking tabs on the fuse mounting plastic, carefully pull the wires aside, and use a small 1/4-inch ratchet socket (possibly 10 mm) on the side screws that hold the ALT fuse legs. Work carefully because the screws are easy to drop.
Conversation Summary
The owner of a 2004 Toyota Camry cannot remove the larger ALT fuse because its metal legs are screwed into the fuse box, and the center section will not separate after the main screws are removed. The expert advises releasing the side locking tabs, carefully pulling the wires aside, and using a small socket on the side screws, noting that the design is awkward and the screws are easy to drop.
