1999 Toyota Camry Won't Jump Start
PATELVB
1999 Toyota Camry, 140,000 miles. Today, I tried to start my car and nothing happened, power locks, lights, nothing will start in the car now. The battery is fairly new. Attempted to jump-start car twice and was unsuccessful both times, although, when the car was initially jump-started, the light around the key ignition and a service light would turn on, but would quickly turn off once I inserted key into ignition and attempted to turn car on.
Oct 7, 2007 at 3:18 PM
  • 31,937 POSTS
Hi there,
It sound like you have a poor connection with your jumper leads, try fitting a fully charged battery and starting it, When running test alternator charge rate. Don't attempt to change batteries with engine running, Bench charge your battery and re fit.
Mark (mhpautos)
Oct 7, 2007 at 4:00 PM
Suggested Repair
Check for a poor jumper-lead connection. Fit a fully charged battery, or bench-charge the existing battery and reinstall it, then try starting. Once running, test the alternator charge rate. Do not swap batteries with the engine running.
Conversation Summary
A 1999 Toyota Camry with about 140,000 miles has no electrical power and will not start. The fairly new battery and two jump-start attempts did not restore power; ignition and service lights briefly came on during a jump, then went out when the key was turned. The expert advised checking the jumper connections, installing or refitting a fully charged battery, and testing alternator output once the engine is running.
