1997 Toyota Camry AC On Light Blinks
FOURBOYZ
My AC "on" light continues to blink and when it does my AC will not cool.
97 Toyota Camry LE 175000 miles Auto transmission
Sep 20, 2007 at 1:59 PM
FISHERMAN
  • 937 POSTS
[quote:23aef692a1="fourboyz"]My AC "on" light continues to blink and when it does my AC will not cool.
97 Toyota Camry LE 175000 miles Auto transmission[/quote:23aef692a1]
First at all check your A/C belt for proper tension,
there is a low pressure switch that "cuts" the magnetic clutch in case of lack of refrigerant or loose belt...
also check the relay of the magnetic clutch.
Let us know what do you find!
Sep 20, 2007 at 2:33 PM
Suggested Repair
Check A/C belt tension, the low-pressure switch that cuts the magnetic clutch when refrigerant is low or the belt is loose, and the magnetic clutch relay.
Conversation Summary
The owner of a 1997 Toyota Camry LE says the AC on light blinks and the system stops cooling. The expert recommends checking belt tension, the low-pressure switch that disengages the magnetic clutch, and the magnetic clutch relay.
