1994 Toyota Camry Oil Leak
JMURJI
My car is leaking oil. When I drive, and turn on my heating, i can smell a little bit of burning oil (a little stronger smell when i'm going slower, or am slowing down.) I usually takes about 15mins for the smell to start, and doesn't happen all the time.
The oil leak is on the front right passenger side. I took the car to a local mechanic, and was told 1) replace cam seal and crank seal 2) replace rocker cover gasket and 3) replace oil pan gasket. Seems to me like that's a little excesive, and they don't know exactly what's wrong. Any idea on how i can find out what needs to be done? Any way i can do the repairs myself? Any quick fixes (ie. oil sealant). I really don't drive the car too much, maybe 500km per month.
Thanks
Apr 12, 2006 at 3:59 AM
LOSONE
  • 1,616 POSTS
The best way to find an oil leak is wash the engine when the car is cold. Run it a bit and see where the oil leak eminates.
All Camrys, but especially four-cylinders, can have a problem with engine sludge. Check the V6 for head gasket leaks. Check four-cylinders for oil leaks at the O-ring of the distributor. Check coolant levels and watch for leaks.
Let me know
Apr 12, 2006 at 5:04 AM
Suggested Repair
Wash the engine while cold, run it briefly, and trace where the oil first appears. Also check for sludge, a distributor O-ring leak on a four-cylinder, head-gasket leakage on a V6, and the coolant level before replacing multiple seals.
Conversation Summary
A 1994 Toyota Camry owner reports an oil leak on the front passenger side and a burning-oil smell after driving with the heater on. A shop recommended replacing the cam, crank, rocker-cover, and oil-pan seals, which the owner considered excessive. The expert advised cleaning the cold engine and running it to locate the leak, while also checking for sludge, engine-specific leak points, and coolant loss.
