It's most likely your Oxygen Sensor. Disconnect your battery (negative terminal) and replace the sensor. To clear the fault on your computer, just unplug the 15A EFI fuse under the hood for 30 seconds and plug it back in. That should solve your problem.
SPONSORED LINKS
Sunday, March 12th, 2006 AT 1:14 PM
