1994 Toyota Camry 4 cyl Front Wheel Drive Automatic
I found out lately that my check engine light comes up frequently even when the car is fully on motion and when it does, the engine will go off within a minute and it will take atleast 3 attempts to start it. I changed the fuel pump but the problem still persist. Also, the car do hesitate if accelerated. You got to help me here. Thanks
updated 2-5-09
Pls can u advice me on how to solve these problem codes emanating from my 1993 Toyota Camry car:
Code 12; no RPM signal to ECU while cranking
Code 13: RPM signal circuit open or short
Code 14: no Ignition Reference signal
Code 16: Transmission control circuit problem
Code 21: Oxygen sensor or circuit problem
Code 22: coolant temperature circuit open or closed
Code 24: Air temperature sensor circuit open
Code 25: Lean exhaust
pls I really need somene to explain these codes and faults to me and how I can get them fixed. Pls be simple as possible and let me have the reply soonest. Thanks
SPONSORED LINKS
Friday, January 30th, 2009 AT 8:47 AM
