Keeps setting check engine light; code P0300
189,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
JOHNSTELTING
Sets codes P0300, P0301, P0303, P0305. I have used stp injector cleaner in gas tank every few fill ups; for a while this fixed for a month or so but now only goes away for a couple of miles. I took to shop and had injectors cleaned only lasted one day. That day I drove the car about 40 miles mostly highway with no problem. The next morning I drove about 8 miles city streets when it set the same codes again. After warm up it has a rough idle, and when accelerating from a stop I have to push gas pedal more than normal as it is sluggish until the rpm get a little higher then it takes off. It always set the same codes.
Thanks for any input you can give me as I do not have the money for new injectors unless I am sure that they are the problem.
May 13, 2014 at 4:36 AM
HMAC300
  • 48,601 POSTS
these are misfire codes and are very hard to diagnose. best to have a pro do this as there are a few sensors that can be causing this as well as low fuel pressure and or low compression
May 13, 2014 at 4:59 AM
