HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Electrical
Alternator
Not Charging
2007 Toyota Camry Alternator
ROSEANN07
MEMBER
2007 TOYOTA CAMRY
4 CYL
2WD
AUTOMATIC
20,768 MILES
How do I check to see if the alternator is bad?
Tuesday, August 17th, 2010 AT 9:46 AM
MMPRINCE4000
MECHANIC
Easiest way is to get a hand held volt meter, with engine running and probes on battery posts, voltage should be 13.5- 14.0, if not then alternator or battery connections are coroded.
Tuesday, August 17th, 2010 AT 10:17 AM
Please
login
or
register
to post a reply.
Related Alternator Not Charging Content
Can't Figure Out Problem In The Charging System
Gauges (speed, Rpm, Gas) Went Dead While Driving. Replaced Battery, Battery Cables, And Alternator. Checked All Fuses, Including Ones...
Asked by
Melfina
7 IMAGES
1995
TOYOTA CAMRY
VIDEO
Alternator Replacement
Instructional repair video
GUIDE
Got a red battery warning light on? This most likely means the alternator has gone out and needs a replacement. To confirm the failure use a voltmeter to test the alternator...
1996 Toyota Camry Bad Alternator Or Battery?
Other Category Problem 1996 Toyota Camry Engine Size Unknown Wheel Drive Type Unknown Automatic 150, 00 Miles The Other Day My Car...
Asked by
kait
1 ANSWER
1996
TOYOTA CAMRY
1993 Toyota Camry Charging Problem
Engine Mechanical Problem 1993 Toyota Camry 4 Cyl Front Wheel Drive Automatic 249k Miles If This Car Sits For 3 Or More Days, It Needs...
Asked by
tns1983
1 ANSWER
1993
TOYOTA CAMRY
1993 Toyota Camry Charging System Problem
I Was Driving Around Town And I Took A Rough Left Turn And My Windows, Sunroof, Electric Door Locks, Gauges, Heat/air Conditioning Went...
Asked by
dgallagher92
3 IMAGES
1993
TOYOTA CAMRY
Bad Ground? Wire Sorting? Alternator Problems!!!
So. It All Started A Few Months Ago. Was Driving The Car Like Normal And Came To A Stop And Charge Light And Brake Light Came On...
Asked by
kylehulberg
1 ANSWER
1989
TOYOTA CAMRY
VIEW MORE
How to Test an Alternator
