1993 Toyota Camry Charging Problem
TNS1983
  • 1993 TOYOTA CAMRY
Engine Mechanical problem
1993 Toyota Camry 4 cyl Front Wheel Drive Automatic 249k miles
If this car sits for 3 or more days, it needs a jump start. Driven every other day, it's fine. I have installed new: alternator, distributer, cap, wires, and battery (3rd one now in a year). I have changed the ECM, and had all connections checked, and seem fine. The coil was tested, and it is good. All accessories are turned off daily. Any ideas would be greatly appreciated as the car is not driven much, so I am keeping the battery disconnected. Thanks, Tony
Tuesday, January 27th, 2009 AT 7:58 AM
DOCFIXIT
  • 18,828 POSTS
A circuit is on draining battery. Need to have a battery drain test done to identify circuit and item so you can repair. Like trunk light, glove box, vanity morror are some common ones.
Tuesday, January 27th, 2009 AT 8:14 AM
