2005 Toyota Camry FRONT RIGHT WHEEL IS SHAKING
2005 TOYOTA CAMRY
115,000 MILES • 4 CYL • FWD • AUTOMATIC
BAD4SO
The front right wheel has a noticeable shake. The Tire Tech could not diagnose the problem, he just showed me the wheel has a "play" when mounted and of course it's not on the other wheels. Also, when I turn to the left, it makes clicking sound as if it touching something, like the stone shield. This only started happening after I changed the front bearings. I just had someone take a quick look but the person didn't see anything from just looking. What do you think is causing the "play" on the wheel and the sound? I don't feel anything on the steering wheel. You just hearing a noticeable humming sound while driving.
Sep 19, 2010 at 3:50 AM
F4I_GUY
  • 3,302 POSTS
If you are hearing a humming sound while driving, it may be a faulty wheel bearing or a mis-installed wheel bearing. I would definitely go back to the repair facility that did the work for two reasons:
1)There is play in the wheel, which is a major safety concern
2)There is a humming noise, which is probably caused by the wheel bearing, so the problem was not fixed.
Goodluck.
Sep 19, 2010 at 5:26 AM
MERLIN2021
  • 17,250 POSTS
This is a loose and or worn bearing, if not properly torqued when installed, it gets destroyed real fast... you need to re do the bearing. Torque to 217 ft lbs with a torque wrench.
Sep 19, 2010 at 5:30 AM
