1997 Toyota Camry Steering Wheel Shake
BRYAN
Hi guys! 97 toyota camry , 154,00 miles . Steering wheel shakes from speeds of 20mph and up and also while braking. Also a whistling sound coming from front left tire. Could this be a brake rotor? Thanks!
Nov 28, 2006 at 10:40 AM
BACKYARDMECHANIC
  • 337 POSTS
You may have more then one problem. The fact you say the wheel shakes when you apply the brakes leads me to believe the rotors are wrapped and need to be replaced. After replacing them see if the shake goes away. I suspect this will correct the problem. However if it doesn't the next thing to do is to have the wheels balanced. If you still have the problem then you will need the have the front end inspected.
Backyardmechanic 8)
Dec 3, 2006 at 8:29 AM
Suggested Repair
Replace the warped brake rotors and recheck the shake. If it remains, balance the wheels; if it still continues, have the front end inspected.
Conversation Summary
A 1997 Toyota Camry with about 154,000 miles has a steering wheel that shakes from 20 mph up and while braking, plus a whistle from the front left tire. The expert says more than one issue may be present and that brake shake points to warped rotors that should be replaced. If the shake remains, the wheels should be balanced, and if it still continues, the front end should be inspected.
