Everythign seems to be working correctly and the only logical explanation left is a failing thermostat or an inaccurate gauge/sending unit. Thermostat might get stuck in the closed position intermittently and when that occurs, the temperature would go up.
Under such conditions there would be no smoke as coolant is available and there are no leakages.
Friday, September 17th, 2010 AT 8:01 AM
