2000 Toyota Camry Temp. Gauge moves towards hot on longer t
DEVONPARSON
  • 2000 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • MANUAL
  • 150,000 MILES
The temp. Gauge will move towards the red after about 40 minutes of driving. If the A/C is on sometimes the gauge will not increase towards the red. If the car is in neutral the problem seems to get worse. I have checked the coolant level and it seems to be full. I also had the thermostat checked at the mechanic and it is fine. I am a car neophyte and dont know what to do. Please help. Thanks
Monday, September 14th, 2009 AT 5:06 PM
If you're not actually overheating or boiling over the coolant temperature sensor or the engine temperature gauge switch is misleading you or the gauge itself is out of calibration. Get it checked-
Monday, September 14th, 2009 AT 7:33 PM
