HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Engine
Oil Change
2005 Toyota Camry
JOSEPH BAKULA
MEMBER
2005 TOYOTA CAMRY
2005 Toyota Camry
how do I reset the maint required light, I had just done a oil change.
Saturday, October 10th, 2009 AT 1:28 PM
OBXAUTOMEDIC
MECHANIC
Ok,
Turn Ignition key off with Odometer Reading Showing.
Turn Ignition switch to on while holding Reset Button.
Hold for at least 5 seconds
Odometer should read 000000 and light should go out.
Saturday, October 10th, 2009 AT 1:37 PM
Please
login
or
register
to post a reply.
Related Oil Change Content
Oil Is Leaking After Change
2005 Toyota Camry 2.4 L 4 Cylinder100,000 Miles, Oil Is Leaking After Oil Change From Natural Oil To Synthetic Oil. Did The Switch From...
Asked by
treeshademechanic
1 ANSWER
2005
TOYOTA CAMRY
VIDEO
Oil Change & Filter Replacement Toyota
Instructional repair video
GUIDE
New Car Service
When you buy a new car the most important thing you can do is keep the services up and give your car a visual inspection both under the hood and under the car. Although the...
2007 Toyota Camry Oil Change
I Took My Car To A Local Jiffy Lube For An Oil Change. After I Left, We Headed Out Of Town. As We Were Driving, A Huge Puff Of Black...
Asked by
Rochow
1 ANSWER
2007
TOYOTA CAMRY
2010 Toyota Camry Oil Filter Removal
I Have A New Canister Type Filter That You Only Replace The Filter Material Inside. I Had The First Oil Change Done At An Oil Change Place...
Asked by
JohnnyHayes
1 ANSWER
2010
TOYOTA CAMRY
1987 Toyota Camry Oil Change Mystery
I Took My 87 Camry Wagon For An Oil Change. After Driving About 330 Hwy Miles The Engine Died. There Was Less Than 1/2 Cup Of Oil In The...
Asked by
dkbrown100
1 ANSWER
1987
TOYOTA CAMRY
2000 Toyota Camry Changing The Motor Oil
My Camry Has Been Burning Oil More Than Normal Lately And I Would Like To Know If You Suggest That I Change The Motor Oil To A Heavier...
Asked by
dlm29
1 ANSWER
2000
TOYOTA CAMRY
VIEW MORE
Oil Change and Filter Replacement BMW 525i
Oil and Filter Chevrolet Camaro 6.2L
Oil Change & Filter Replacement Kia Rio
