2003 Toyota Camry Fan Motor
2003 TOYOTA CAMRY
OBIWAN1576
2003 Toyota Camry 4 cyl Front Wheel Drive Automatic
My fan motor is not moving and it caused my engine to overheat. For the moment it seems the radiator is ok and I believe there is no problem there. As far as the a/c, it would get cold at some point then all of a sudden the coldness would just go away but the blower would still be on. Please help!
Oct 22, 2009 at 10:56 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check cooling fan relay. if the radiator fan does not come on when the A/C is switched on then the fan motor will need replaced.
Oct 22, 2009 at 11:02 AM
JOE C.
  • 25 POSTS
I agree. You may have two problems. the cooling fan for the radiator, and you may have a leak in the ac system, be down on refrigerant, have a bad AC compressor, the belt could just be loose, etc.. all those things could make the ac not blow cold.
Oct 22, 2009 at 7:25 PM
