Hi there,
This is the E.C.U. Fault light. The ecu has set a fault code for something in the engine management system, This code can be retrieved by bridging TE & E1 at the diagnostic link under the bonnet, with the ignition on, the light will flash a code it might be 2 flash's, pause and 4 flashes, this is code 24 and so on.
These codes are use to determine faults that have developed in the electronics and sensors.
Mark (mhpautos)
SPONSORED LINKS
Friday, December 21st, 2007 AT 11:42 PM
