2003 Toyota Camry Coolant Temp Code
KPATEL03909
I have 2003 Camry LE. I have been getting error code that says "Coolant Temperature Below Normal Thermostat level".
I have had three different mechanics tell me three different solutions.
Flush the Radiator
Replace the Sensor
Replace the Thermostate
Dealer is saying I have to do all three.
I am trying to find out if anyone knows solution for this error code.
Thanks
Kp
Mar 22, 2006 at 6:59 AM
FISHERMAN
  • 937 POSTS
I think the expensive part its the sensor..
I recomend you to start flushing the coolant and replace the thermostat and see if that solve the problem..
Amazing how it fail that soon!
any warranty on the car?
its almost new!!
Mar 22, 2006 at 1:24 PM
BLACK HORSE
I just had the same problem.
Check with a cooling guesh for leaking special for water pump and radiator cap then is fix it pour radiator fluid warma up without radiator cap and fill it till air is out. :D
Mar 22, 2006 at 1:41 PM
KPATEL03909
Thanks for your reply. I did flush the coolant once and light came back after about 3 days or so. As for Warranty, well i would be from time stand point but I have put on 65K miles (all highway) on it already so don't think so.
Kp
[quote:bde507a79c="fisherman"]I think the expensive part its the sensor..
its almost new!![/quote:bde507a79c]
Mar 23, 2006 at 2:53 AM
Suggested Repair
Start with a coolant flush and thermostat replacement rather than the more expensive coolant temperature sensor. A flush was already done and the light returned after a few days, so replace the thermostat next. Also check for cooling-system leaks, especially at the water pump and radiator cap, and bleed air while refilling.
Conversation Summary
The owner of a 2003 Toyota Camry LE has a check engine light for coolant temperature below the normal thermostat level. Mechanics separately suggested a radiator flush, sensor replacement, or thermostat replacement, while the dealer recommended all three. An expert advised flushing the coolant and replacing the thermostat first because the sensor is more expensive, and asked about warranty. The owner said a flush had already been done and the light returned after about three days; with about 65,000 highway miles, warranty coverage was unlikely. Another owner suggested checking for leaks at the water pump and radiator cap and bleeding air from the system.
