1996 Camry overheats only with Thermostat in
TOMMYAUGUSTIN
  • 1996 TOYOTA CAMRY
I recently replaced the radiator on my 1996 Camry 4cyl and replaced the thermostat along with it. My car then would start to overheat after driving only about 500 yards. I took the thermostat out and it ran fine with temp gauge just below midline like it used to. I then returned the thermostat and got a new one (thinking the thermostat was defective) and put the new one in boiling water and watched it open (suggestion to test it). I then put the new thermostat I tested in and my car overheats again. Is the store giving me the wrong thermostat? Also I noticed the fans never come on when I have the thermostat in even when getting hot. Should I just run my car without the thermostat?
Talked to a mechanic on the phone and he thinks that my water pump is probably bad and that it doesn't spin fast enough to keep the engine cool with the thermostat, but is spinning enough to keep it cool without the thermostat. He reccommends replacing the water pump.
Wednesday, March 7th, 2007 AT 3:58 PM
2CARPRO JACK
  • 11,533 POSTS
Is there any air in the system? T-stats and sensors cant read air, so they wont work unless in fluid. Let the car get warm and shut it off and let it set for a few minutes, remove cap and see if the fluid level drops. Sometimes they can be difficult because the engine sits higher than the radiator
Thursday, March 8th, 2007 AT 7:48 AM
Related General Content
