2003 Toyota Camry Oil Light and Knock Fix
NAILKA1
2003 Toyota Camry 2.4L 92000 miles. When car gets warm, the oil light comes on and there is a knock. I want to change the rod bearings and the oil pump, do you know if I can do this without removing the engine?
Apr 12, 2007 at 4:41 AM
  • 75,988 POSTS
[quote:e11e137620="nailka1"]2003 Toyota Camry 2.4L 92000 miles. When car gets warm, the oil light comes on and there is a knock. I want to change the rod bearings and the oil pump, do you know if I can do this without removing the engine?[/quote:e11e137620]
Yup! the hard way from underneath-just make sure everything is clean
Apr 12, 2007 at 10:11 AM
Suggested Repair
Rod bearings and the oil pump can be replaced from underneath without removing the engine. Work carefully and keep all parts and the work area clean.
Conversation Summary
The owner of a 2003 Toyota Camry 2.4L with 92,000 miles reports that the oil light comes on and the engine knocks once the car is warm. They asked whether the rod bearings and oil pump can be replaced without removing the engine. The expert said yes, though it is the hard way from underneath, and advised keeping everything clean.
