2000 Toyota Camry overheating
JOEYAIR
  • 2000 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 200,000 MILES
The engine is a little hotter than usual what should I check
Saturday, March 28th, 2009 AT 6:53 PM
ZACKMAN
  • 4,202 POSTS
Do you have enough coolant?
Are the fans working? Can you verify their operations?
When is the last time you replace the thermostat?
Do you have any coolant leak?
If you turn the heat in the passenger compartment, does that reduce the engine temperature (based on the temp gauge)?
Sunday, March 29th, 2009 AT 3:26 AM
JOEYAIR
Yes to all of your questions except the last one I havent tried to put on the heater yet I will today thank you Joey
Monday, March 30th, 2009 AT 11:50 AM
ZACKMAN
  • 4,202 POSTS
Also, check for possible plugged up radiator.
Monday, March 30th, 2009 AT 10:35 PM
