1999 Toyota Camry What parts should I replace along with my
TEDRED
MEMBER
1999 TOYOTA CAMRY
4 CYL
2WD
AUTOMATIC
106,000 MILES
It's time to replace my timing belt. What additional parts would I be smart to replace at the same time ( e.G. The water pump)?
Thursday, August 14th, 2008 AT 2:14 AM
MECHANIC
Hi there,
You may replace the water pump if you wish, but there is no need to if it is ok, I would just check the tensioner & idler pulley bearings but once again if ok only change them if you want to.
