This can be done without the belt? Also, I was referencing the Haynes Repair Manual for the car which is somewhat confusing. It talks about doing the compression stroke with the belt on. Also, on the crank pulley there is a blue dot, which I assume should line up to the 0 DEGREES BTDC markings on the cover, however when Number 1 is TDC its not close.
Thanks.
Gerald Butcher
Saturday, November 10th, 2018 AT 8:10 AM
