It sounds like a bad idle air control valve, is your check engine light on? It may or may not be for this one, also you may have a vacuum leak, get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs!
Check the PCV, if clogged it can do this.
Thursday, May 23rd, 2019 AT 6:54 PM
(Merged)
