HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Engine
Cylinder Head
1999 Toyota Camry Engine Specifications
SHEMCBO
MEMBER
1999 TOYOTA CAMRY
Engine Mechanical problem
1999 Toyota Camry 4 cyl Two Wheel Drive Automatic
I need to know the specifications for the Main Bearing Torc, Rod Bearing Torc and the cylinder head torc
Monday, September 22nd, 2008 AT 6:44 PM
MECHANIC
Here you go Sir
1. Head
Step1 36ft lbs
Step2 additional 90 deg turn
2. Rod
Step1 18ft lbs
Step2 additional 90deg turn
3. Main
Step1 43ft lbs
Monday, September 22nd, 2008 AT 7:40 PM
Please
login
or
register
to post a reply.
Related Cylinder Head Content
My Car Engine Is Broken! What Should I Do?
Hello, My 1996 Toyota Camry Le 2.2l Automatic Has A Engine That Is Broken. It Also Has These Following Things Damaged: Cassette Player/...
Asked by
sjishaq
1 IMAGE
1996
TOYOTA CAMRY
VIDEO
Blown Head Gasket Test Video
Instructional repair video
GUIDE
Cylinder Head Gasket Replacement
A cylinder head gasket is used to seal the combustion charge between the cylinder head the engine block, this gasket also controls the flow of coolant between the two as...
Timing
How Do I Tell If My 1991 Camery Has A Interference Head Or Not
Asked by
trenham
1 ANSWER
TOYOTA CAMRY
1998 Toyota Camry Timing
I'm Currently Working On A 1998 Toyota Camry 2.2 Dual Head Care For A Friend. The Car Was Torn Down By Someone Else Who Did Not Mark The...
Asked by
auntrere87
1 ANSWER
1998
TOYOTA CAMRY
Fed Jdm (used Japanese Engine) Replace A California...
I Purchased An Engine, Long Block, From Engine World Usa (ewusa). Ordered A California Emissions Engine, The Head Doesn't Have A Hose...
Asked by
idwtoo
1999
TOYOTA CAMRY
1999 Toyota Camry Timing Belt
The Crank Pulley Is At Tdc. I Am Having A Hard Time Lining Up The Cam Pulley. Could I Have It Out 180 Degrees? Is There Only One Way For It...
Asked by
longrun
1 ANSWER
1999
TOYOTA CAMRY
VIEW MORE
Cylinder Head and Oil System Install Ford
Replacing the Cylinder Heads
How to Build a Ford 302 Small Block - Part 7:
