1999 Toyota Camry Timing belt
LONGRUN
  • 1999 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 125,000 MILES
The crank pulley is at TDC. I am having a hard time lining up the cam pulley. Could I have it out 180 degrees? Is there only one way for it to go? It is very difficult to line up the hole in the pulley with the punch on the head, any suggestions?
Thanks Greg
Sunday, January 13th, 2008 AT 2:22 AM
  • 31,937 POSTS
Hi there,
Use a small mirror and a torch to view the hole in the cam pulley and the notch, the hole should be at 12-00 O'clock. Do not rotate crank or cam with out belt as valve damage will occur.
Mark (mhpautos)
Sunday, January 13th, 2008 AT 5:20 AM
