HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Engine
Cylinder Head
Timing
TRENHAM
MEMBER
TOYOTA CAMRY
How do I tell if my 1991 camery has a interference head or not
Wednesday, October 24th, 2007 AT 7:54 PM
MECHANIC
Toys interference cylinder heads.
TOYOTA
1986-95 1.5L Tercel
1981-83 2.2L Pickup
1984-87 2.4L Pickup
1982-88 2.8L Celica Cressida
1987-94 3.0L 4-Runner
SPONSORED LINKS
Thursday, October 25th, 2007 AT 12:30 AM
Please
login
or
register
to post a reply.
Related Cylinder Head Content
1999 Toyota Camry Engine Specifications
Engine Mechanical Problem 1999 Toyota Camry 4 Cyl Two Wheel Drive Automatic I Need To Know The Specifications For The Main Bearing...
Asked by
shemcbo
1 ANSWER
1999
TOYOTA CAMRY
VIDEO
Blown Head Gasket Test Video
Instructional repair video
GUIDE
Cylinder Head Gasket Replacement
A cylinder head gasket is used to seal the combustion charge between the cylinder head the engine block, this gasket also controls the flow of coolant between the two as...
My Car Engine Is Broken! What Should I Do?
Hello, My 1996 Toyota Camry Le 2.2l Automatic Has A Engine That Is Broken. It Also Has These Following Things Damaged: Cassette Player/...
Asked by
sjishaq
1 IMAGE
1996
TOYOTA CAMRY
1998 Toyota Camry Timing
I'm Currently Working On A 1998 Toyota Camry 2.2 Dual Head Care For A Friend. The Car Was Torn Down By Someone Else Who Did Not Mark The...
Asked by
auntrere87
1 ANSWER
1998
TOYOTA CAMRY
Where Did My Timing Belt Go?! >:-/
1988 Toyota Camry Dlx V6 208,000. I Was Having Some Trouble With The Car Having A Huge Lack Of Power In The Low End And Finally Figured Out...
Asked by
t6rivals
TOYOTA CAMRY
Crankshaft Pulley Removal
Crankshaft Pulley Removal Engine Mechanical Problem 1994 Toyota Camry 4 Cyl Two Wheel Drive Automatic I Need To Remove The Crankshaft...
Asked by
Harvey1402
1 ANSWER
TOYOTA CAMRY
VIEW MORE
SPONSORED LINKS
Cylinder Head Installation
How to Build a Ford 302 Small Block - Part 6:
Taking the Cylinder Heads Off!
Online car repair manuals
