1998 Toyota Camry vibration
103,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOB MUEHLBAUER
Noticeable vibration in steering wheel when transmission is in reverse or forward gears when standing still. (Almost makes my fingers tingle.) Not as noticeable when vehicle is moving, but then again the road vibrations may be over powering the sensation.
Feb 28, 2009 at 10:56 AM
GRSMNKY
  • 33 POSTS
my first guess would be the engine and trans rubber mounts. Easy way to check this is to have a person changing gears reverse and drive back and forth and watch for engine shift. If engine jumps front and back during shift, time to replace mounts. Normal wear due to rubber wear and drying out. If not replaced, flexing can break the exhaust pipe at flex connection and that will cost even more to replace since they are sold with a catalytic converter.
Mar 1, 2009 at 4:03 AM
