2002 Toyota Camry low frequency vibration
55,000 MILES • 6 CYL • FWD • AUTOMATIC
DANPEIGHTEL
my camry makes a recurring low frenquency vibration through the chassis during high speed interstate driving . Different road surfaces make it more or less noticeable, especially concrete and coarser black top.The vibration is felt in the steering wheele and the seats. The car is on it's second set of tires two of which are close to gone with only 25000 miles on them.
Jul 14, 2009 at 7:43 PM
  • 31,937 POSTS
Hi there,
I would start with checking that the front sub frame bolts are tight, you should back each off and re tighten, this is or should be done during servicing, its in the book also check all suspension & steering components, start here.
mark (mhpautos)
Jul 14, 2009 at 7:45 PM
