Start here:
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
The tie rod ends must be removed and this will affect alignment "toe", so car alignment should have been checked after install.
Motor and transmission mounts should also have been inspected for wear.
Look under car for transmission drain plug, if there is a second drain plugto the rear of trans plug, this is differential drain. They MUST refill differential to proper level, since removing CV shafts will cause most of fluid to leak out.
SPONSORED LINKS
Monday, October 26th, 2009 AT 8:40 AM
