rpm fluctuate when idling
129,000 MILES • 4 CYL • 2WD • AUTOMATIC
ELO PAC
When I arrive to a complete stop my rpm's bounce up and down, even to the point where the car acts as though it needs to shut off. I took it to Autozone and the only thing that came up was that the timing belt needed to be replaced. I replacing that as well as the water pump, but I am afraid that that may not by my issue with the rpm's?
Feb 14, 2017 at 12:54 AM
HMAC300
  • 48,601 POSTS
try cleaning the throttle plate on both sides and IAC hole with choke cleaner. do not let an auto parts person diagnose anything for you they do not work on them and are just guessing. If you have a belt on timing chain then it should have been replaced 24,000 miles ago.
Feb 14, 2017 at 1:37 AM
