1997 Toyota Camry Spark plugs
MARKMURPHY
Engine Mechanical problem
1997 Toyota Camry 4 cyl Automatic
Changed my spark plugs and wires, car started sputtering again, a mechanic said we had to use double platnum on it and could not use universal plugs, that it burns the wires. Is this true? And they said it was plug #3. is it numbered left to right if your under the hood looking at the engine? Thanks
Nov 12, 2009 at 2:32 AM
  • 31,937 POSTS
HI there,
You can use standard plugs, but iridium or platinum are better but not mandatory, change all at one time and if you do the leads do all as well, No ! is at the Timing belt end.
Mark (mhpautos)
Nov 12, 2009 at 6:48 PM
