Changing Spark Plugs
FRANK CRAPSON
  • 2003 TOYOTA CAMRY
  • 6 CYL
  • FWD
  • 55,000 MILES
I have attempted to change my spark plugs and find other engine devices blocking access. I was able to access the front three plugs, but when I attempted the rear three, I found a coolant pipe blocking access (which I decided I did not want to remove). Is there an easy way to change the plugs in my Camry XLE?
Thanks
Sunday, August 9th, 2009 AT 5:58 PM
STEVEW84
  • 673 POSTS
You can do it with the intake manifold on, it is just a real PITA. I would recommend taking the manifold off. Shouldn't take you anymore than a 1/2 hour to and hour to take it off. If you have a good assortment of tools at your disposal, this can be done with the intake on, it just takes a wobbly spark plug socket and the correct length extension. Have done it many times
Monday, August 10th, 2009 AT 7:57 AM
FERBIE
  • 2002 TOYOTA CAMRY
Just had my plugs changed for the first time. Car was great and smooth. Original owner. Never had a problem just brought in for mini tune up. Got filters, oil change, and plugs done. Next morning check engine light and vehicle control off lights both on. And car started jerking at 40-50mph. Also, noise coming from glove box area. What did the mechanic do to my car because he doesn't know. He has had it for 5 days just to try and fix the 6 plugs that he changed. Thanks. Please help I have bills to pay and need to go to work. Ps work order says 2.4 4sp, I have a v6. Did he install the wrong plugs?
Thursday, June 13th, 2019 AT 7:19 PM (Merged)
LJMOTORS
  • 6 POSTS
If you send me the entire VIN number on your car I can tell you the part number of the spark plugs your car is meant to take.
There are many things that can cause the kind of problem you are talking about. They could have damaged a coil when installing the spark plugs, or they could have broke/unlodged a hose and it is possible you now have a vacuum leak.
Anyway, send me your VIN and I can tell you what spark plugs you should have.
FERBIE
Vin # 4T1BF30K72U517670
Went to auto store to read codes and the PCM determined that multiple misfires have occured in cylinder 1, 3, and 5.
Also, the fuel system for bank 1 was too lean(location of cylinder 1)
All probable causes for misfires. :
1. Ignition system fault-spark plugs, ignition wires, coil.
2. Vacuum leak
3. Injector fault
4. High or low fuel pressure.
Probable causes for fuel trim bank one:
1. Mass Air Flow Sensor (not it-mechanic tried)
2. O2 sensor
ignition misfire-repair
fuel injector problem
My car was running fine before I brought it in to change the spark plugs. Had NYS inspection done 2 days prior and there were no lights on. So is my car jerking as a result of the spark plus being installed incorrectly? Thanks
BUZZSAW
  • 1,198 POSTS
Sounds like he crossed up the wires, or a coil pac is bad, 1, 3, 5, are on the same side
FERBIE
What is a coil pac? Do you mean he didn't changed them one at a time and that's how he crossed the wires? Thanks
LOSTINMARS
  • 222 POSTS
Just a guess here.
Another thing that can cause this is a bad/clog VVT-I valve on that bank. Maybe he left it unplugged or damaged the connector for it. Or maybe it has just gone bad due to high mileage (i see them going bad around 100k or so) and it is just a coincidence.
This can easily be checked with the factory toyota scanner.
Once again this is a guess.
