Hi there,
You can't quote on a head gasket problem until the head is removed. As there is no way of knowing what work has to be done to the head, there may be cracking, warping, corrosion that needs welding and machining, a very rough estimate for an average repair and the extra parts could be in the order of about $1,200 possibly more or less you also have to take into consideration, coolants, oils, hoses radiator, thermostat, all these may need replacing, you just do not know until it is inspected first hand.
Mark (mhpautos)
SPONSORED LINKS
Monday, May 31st, 2010 AT 9:28 AM
