1997 Toyota Camry Check Engine Light
DBRONSON
  • 1997 TOYOTA CAMRY
1997 Toyota Camry 6 cyl Two Wheel Drive Automatic
I have a 1997 camry, and a fuse was blown and after I fixed it, the check engine light was still one. I was wondering if on a 1997 camry, would the light have to be put of manually, or does that mean there is something else wrong with the car.
Wednesday, July 28th, 2010 AT 8:51 AM
Check engine light On
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis, finding out what's going on.
You can try this: Remove the EFI fuse for 10secs and see if it will pop back up.
Wednesday, July 28th, 2010 AT 8:57 AM
