1997 Toyota Camry check engine light
TAIRQGHAFOOR
  • 1997 TOYOTA CAMRY
  • 4 CYL
  • 200,000 MILES
I bought about 2 weeks ago toyota, it has check engine light, it has 2 codes, one for miss fire and one for EGR valve
I replaced the spark plugs and the EGR vlave, code for misfire is gone but code for EGR is still there. And it ran for 2 days fine but yesterday morning, I started the car , it started fine, but after 10 minutes engine running rough and then died. I tried to start again. It did not start, next I tried agiain, it started, I parked in the garage
please advise me
Tuesday, March 4th, 2008 AT 2:10 PM
  • 31,937 POSTS
Hi there,
You will have to do some basic checks first, Fuel pressure, (fuel pump runs when ignition on for a few seconds) spark and injection pulse. If you can do or get these checked as well as a code read, fault codes dont always turn on the light, and report back with your findings, we can start to look at the causes a bit closer.
Mark (mhpautos)
Wednesday, March 5th, 2008 AT 2:43 AM
