Initiially my car wouldn't heat. As I was driving home it began toknock and as I was backing nto my garage, I noticed smoke under the hood.
Is it out of fluids or what is the problem?
Tuesday, February 9th, 2010 AT 7:33 AM
TOOOMANYTOYS
MECHANIC
Have you checked the coolant level. If you have no heat coming from vents when heat is on, and its smoking and knocking. I would not advise driving the vehicle. Most likely you are low on coolant due to a leak. The cooling system would need to be pressure tested to confirm.
