1997 Toyota Camry ABS
MACEDONIA
  • 1997 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 97,650 MILES
When I start the Car the ABS light sometimes goes of but sometimes stays all the time I drive?
Monday, July 21st, 2008 AT 10:53 AM
MMPRINCE4000
  • 8,548 POSTS
You will need to have the ABS system scanned with a scan tool. Most autoparts stores give free scans, but they only scan the PCM (error codes beginning with "P").
The ABS system needs a chassis scanner ("C" codes).
It could be as simple as a ABS wheel sensor, but you would need to get the specific code.
Friday, March 5th, 2021 AT 11:24 AM
