1996 Toyota Camry Stiff steering/ABS
VINCENT.HKCHUA
  • 16 POSTS
Steering problem
1996 Toyota Camry 4 cyl Two Wheel Drive Automatic 180Kkm miles
1) My 1996 Camry 2.2 steering wheel is now somewhat stiffer than before. As such its self return after taking a turn is very much lesser now. What can be wrong or need to be serviced? Is there no tellltail alarm if something is wrong. Power steering last serviced 5 years ago and the fluid was also replaced.
2) How would I know if my ABS is actually working or what is the best way to test it out?
Dec 14, 2009 at 7:44 PM
BMRFIXIT
  • 19,053 POSTS
check fluids and belt
ABS system if not working or something wrong you would have a warning ABS light on
so if system isn’t working you would have an ABS light on
turn ignition key on
ABS light on
start engine light should go out in few sec
if not ABS system need to be checked for codes
Dec 15, 2009 at 11:53 AM
VINCENT.HKCHUA
  • 16 POSTS
I will get the fluid checked as advised, however which belting are you refering to which can affect the stiffness of the power steering? Thanks.
Dec 15, 2009 at 7:59 PM
BMRFIXIT
  • 19,053 POSTS
