1996 Toyota Camry troubleshooting
1996 TOYOTA CAMRY
DRBANKS07
1996 Toyota Camry
My car wont start at all. I boosted it, and my radio and lights still come on. The car has been sitting in the garage for about a year, but within this year when i would boost it it'll still start. Just recently it wouldn't. I have a new battey and alternator in the car, so im wondering why the car wont start or kick over at all.
Jan 25, 2010 at 9:39 AM
Lets check what's missing if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jan 25, 2010 at 9:46 AM
