2005 Toyota Camry Winter Storage
25,000 MILES • 6 CYL • AWD • AUTOMATIC
STEVBGUD
Toyota says not to disconnect the battery without checking with dealer. This was under airbag section in owners manual, so I assume it affects air bag system.
Want to disconnect battery for winter storage in garage
Thanks
Dec 16, 2007 at 6:46 AM
  • 75,988 POSTS
Yes you can disconnect the battery-Just make sure you have the proper antifreeze protection in the radiator-otherwise it will expand and break something.
You might have to go into computer relearning process when you re-activate the car again.
Dec 16, 2007 at 7:26 AM
