1996 Toyota Camry Belt?
1996 TOYOTA CAMRY
178,786 MILES • 4 CYL • 2WD • AUTOMATIC
PFLEMING
My car makes a quick little roar when I first start my engine then sqeaks while it's warming up. This roar only happens when my car has been sitting for more than 9 hours in at least 40 degrees or lower weather. I never hear this noise in the warmer months. I had it checked out and they thought it was the timing belt, but they weren't sure.
Thanks,
Dec 5, 2007 at 1:50 AM
  • 31,937 POSTS
Hi there,
i would first be checking the condition and tension of the Alternator and Power steering and A/C belts where fitted. Engine timing belts are not normally noisy, but if all other belts are fine, by all means check the timing belt as well.
Mark (mhpautos) :D
Dec 5, 2007 at 12:19 PM
