1996 Toyota Camry rough idle no power
WOLFIE31082
  • 1996 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 210,000 MILES
Filled up gas a couple days ago. The next morning the car started idling rough. Put it in drive has no power and hesitates then chokes down. Have checked vacuum hoses, plugs, wires, distributor cap, rotor
Wednesday, March 10th, 2010 AT 11:26 AM
OBXAUTOMEDIC
  • 3,711 POSTS
When was last Fuel Filter change?
Is Engine Light On? If so and you can take it by your local parts store and ask them to pull codes. Write them down and post here in forum.
You may have pumped the bottom of the tank at gas station and picked up trash, which is now clogging the fuel filter.
Wednesday, March 10th, 2010 AT 11:39 AM
OBXAUTOMEDIC
  • 3,711 POSTS
When was last Tune-Up? Plugs, Cap, Rotor and Wires. If has been a while would suggest at least the plugs, cap and rotor.
Also, is engine light on?
Thursday, March 18th, 2010 AT 6:02 PM
